Safe to start car after 6 weeks?
Old Dec 21, 2003 | 11:33 PM
88irocz28's Avatar
Do I have to somehow prep the motor before I start it or can I simply start it right away? As stated above it hasn't been started in 6 weeks (I was out of town) so the cylinder walls might possibly be dry by now. Thanks in advance .
Old Dec 21, 2003 | 11:35 PM
94 CAMRO Z28's Avatar
Considering most of us in the colder states store the car for at least 3 months a year, I doubt you have anything to worry about. I've never had any issues.
Aaron
Old Dec 22, 2003 | 12:53 AM
scoobysnax83's Avatar
Re: Safe to start car after 6 weeks?
Let her live!!!
Just don't shut her off until she is all the way warmed up. If you do you won't burn off all the condensation in the oil.
Old Dec 22, 2003 | 01:00 AM
S.J.S.'s Avatar
You'll be fine fire her up buddy.
Old Dec 22, 2003 | 05:07 AM
91 GTA Ramair2's Avatar
Yeah I Run AMSOIL in most of my stuff Like the 91 GTA the AMX and my Company Truck's.
but i strat every thing once ta twice a month........
My 80's beeater winter fleet sit's all summer Half of spring Half of Fall,A few of them get used year round,but the winter fleet has convertional oil. they seem do be fine gotta dump a little gas in da carb's but they fire up run fine. i do try to start them once a month but sometime they get start every 2 month's some might sit the whole time. But if they haven't been started for like 9 month's I'll push em in side sump a littel oil down the,m then fire them up let sit a run a for an hour or 2 ,tune them up drive them a bit andthere ready to Go.I start the summer fleat once a month on the Dot tho.repaint any mis hap's.
Old Dec 22, 2003 | 05:11 AM
Oh my I got off the subject there guy sorry.
yeah I'd start it up let it run about 20min. then drive it around fer about an hour put some fresh gas in it .
It should be all good man Maybe check your oil and coolant and stuff then start it up let run 20min. then hti the gas station drive it about an hour or so then it for sure is ready to Roll.
Old Dec 22, 2003 | 08:28 AM
96TransamConvt's Avatar
Isn't there a fuel pump fuse in the fuse box under the hood.. ?
Could always unplug that before starting, to build up the oil pressure before starting.
Old Dec 22, 2003 | 08:32 AM
Yes there is but it's a relay Black Cub plug's in like a fuse tho. normally on the Fire wall or on a fender.
Old Dec 22, 2003 | 09:05 AM
Instead of the risk of getting air in the lines. Just unplug your fuel injectors' fuse.
Old Dec 22, 2003 | 01:29 PM
Is the fuse labeled "fuel Injectors" in the fuse box ? or is it a sepeate relay ?
Old Dec 22, 2003 | 02:38 PM
ssbowtie1's Avatar
Here's a radical idea:
Just start the friggin car its only been 6 weeks!!
Old Dec 22, 2003 | 03:09 PM
HesterZ28's Avatar
I just started mine after 6 months
Old Dec 22, 2003 | 05:19 PM
Antz97ZNJ's Avatar
6 weeks isnt a whole lot of time, plus az doesnt get cold
Old Dec 22, 2003 | 06:11 PM
88irocz28's Avatar
Thanks for your help, everyone . I went out and started it. Ran a little lumpy and lopey at first but evened out in a few seconds. Oil pressure came up instantly. No weird noises. Drove it around an hour or so, let the temps get nice and hot. Seems good to me. Time to change that oil though.
Old Dec 22, 2003 | 06:19 PM
96M6's Avatar
Aaron
3months i wish! Up here in Canada more like 6mohths....half a year!
