Is it safe to rotate the crankshaft?
Old Dec 17, 2008 | 09:10 PM
dubbsix's Avatar
I know there are plenty of posts on how to put the timing components back on.. but what i wanted to know is with my heads off, lifters and oil pump drive out, with the cam BACK IN is it safe to rotate the crankshaft so that the timing marks line up on the sprockets?
Old Dec 17, 2008 | 09:21 PM
evilundisguised's Avatar
Sure - is there another way to line them up?
Old Dec 17, 2008 | 09:49 PM
dubbsix's Avatar
Well i guess it doesnt hurt to ask.. my first cam swap.
Old Dec 17, 2008 | 09:53 PM
No problem. You'll have to rotate again when assembling your valvetrain. What was the concern, if I may ask?
Old Dec 17, 2008 | 09:57 PM
dubbsix's Avatar
Rookie question... I guess afraid that something would be thrown off it stuffs rotated without all the valvetrain installed. I was pretty sure it would be OK, but like i said.. i'd rather ask and be sure since the budget is so tight.
Old Dec 17, 2008 | 10:09 PM
Nope, the only way to throw stuff off (of timing, at least) is to misalign those dots. Make sure they're lined up, then rotate the crank 2 full turns clockwise, and be sure they line back up.
Old Dec 18, 2008 | 12:21 PM
dubbsix's Avatar
Thank you. How dead on do they need to be? Perfectly aligned over one another?
Old Dec 18, 2008 | 12:34 PM
Green96Z's Avatar
Pointing straight at each other. Crank pointed straight up, cam pointed straight down.
Old Dec 20, 2008 | 08:29 PM
dubbsix's Avatar
This look right?
Well got the timing chain back on, but wanted to know if things looked right.
Old Dec 20, 2008 | 09:15 PM
Kevin Blown 95 TA's Avatar
Yes. Be sure to do a good job of cleaning those gasket surfaces.
Old Dec 20, 2008 | 09:20 PM
dubbsix's Avatar
Thanks. Probably cant see it from the pic but i've pretty much scraped the holy heck out of the timing cover surface.. i still need to take some thiner to the head gasket surface though.
Old Dec 20, 2008 | 09:52 PM
<Puck>'s Avatar
Shoebox's site has an awesome animated gif of the cam/sprocket timing mark configurations and the corresponding piston positions.
I don't want to hotlink to it since its fairly large and don't want to suck his bandwidth, but it is easy to find and worth a look at if you feel nervous at all.
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
rideordie
Sep 7, 2015 08:22 AM
Str8hp
Parts Wanted
Aug 25, 2015 06:03 PM
Slayer
Aug 17, 2015 03:55 PM
