92-93 Throttle Body & 94-96 throttle body?
Old Dec 18, 2008 | 09:40 PM
mrl510's Avatar
What is the difference between the 92-93 throttle bodies and the 94-96 throttle bodies. Im looking to buy a 58mm and id just like to know? Thanks
Old Dec 18, 2008 | 09:49 PM
The early throttle body has a provision for the TV cable for the non-electronic transmission and a different IAC.
Old Dec 20, 2008 | 11:16 PM
mrl510's Avatar
so can i not use a 94-96 tb on my 93? I have my stocker to steal stuff off of if i have to.
Old Dec 20, 2008 | 11:47 PM
You won't have any provision for the TV cable, unless you can figure out how to convert it somehow.
You could swap out the bottom coolant plate to be able to retain the 93s IAC. Otherwise, you will have to change the electrical connector on your engine harness to fit the later IAC.
warmeck
May 1, 2015 11:30 AM
mark0006
Apr 21, 2015 12:42 PM
CARiD
Feb 9, 2015 09:35 AM
lt1-xjs
Jan 17, 2015 07:52 PM
