S.E.S. light
Old Mar 25, 2004 | 04:03 PM
ls6Bird2001's Avatar
S.E.S. light
I have a 95 Z28 with a service engine light on. The code is 36 high resolution pulse circuit. After I drive the car for about 10 miles it will die. My ? is what in the does this mean? & what in the hell do I do about it?
Old Mar 25, 2004 | 04:26 PM
DTC 36 indicates that the Optispark is not providing the high resolution pulse pattern, required to accurately adjust the ignition timing. Lacking the high resolution pulse, the PCM will default to the low resolution pulse, which simply means the timing may not be quite as accurate. But it shouldn't cause the engine to stall.
You might want to check the harness connections for the Opti to make sure they are not corroded.
Old Mar 25, 2004 | 05:24 PM
Thanks for the info.
dluna333
15
Mar 13, 2015 12:30 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
Jlo
Feb 3, 2015 09:41 PM
squarehead
Jan 15, 2015 07:02 PM
