rwhp/tq guess's?
Re: rwhp/tq guess's?
I think 345 is achievable with that cam, but to say AT LEAST 345 without any numbers to support it is a stretch. If the car isn't capable of 360 RWHP, you can grow a beard near it and dump a ton of ice on top and it still won't do it.
NO way! I thought if you used enough ice and waited long enough that you could achieve any number you wanted
I was just kidding man.
I think that cam is capable of 350+ RWHP or maybe a little more, but it takes a perfect running car and setup to get that, which is why I always tend to give advice a little on the low side so that people aren't disappointed in case they don't get what they expected based on that advice.
For example I pulled 348 RWHP out of my 233/239 in an automatic car. That will probably be 360 or just a tad more in a 6 speed. BUT, I invested in quality parts I KNEW would work well together and did the install myself to ensure everything was perfect. Most people save here and there so obviously not everyone is going to get numbers that high.
BTW, hotcams in 350s are through a cutout and usually a ton of boltons.
Originally Posted by ChrisUlrich
I know with lt's I should have about 360 because thats where they usually end up I was told... Doesn't the Hotcam give the LT1 like 300rwhp?
This cam has a much bigger lift and a longer duration plus its supposed to mesh great with the stock heads I heard. Am I wrong on this?
Originally Posted by Z95m6
Lots of people with bigger cams on stock heads don't even make 360rwhp.
JMO
Originally Posted by dmoor88
Probably because the LT1 heads can only handle so much lift.
Anything really over .500 you are just pissing into the wind on stock heads.
Actually Dave has heard many people dynoing 340-350rwhp with this cam and lt's and some even in the 360 range and someone who hit 380 but heard he was a liar so he took it as a possibility. This cam goes excellent with the stock heads... thats why it makes good numbers.
They sell a bigger cam 230/236 but it makes less power. Bigger is not always better with cams... at least thats what i'm told
Actually, the 227/233 wasn't in stock but the next size up and The bigger one cost more, but he told me i'd get more power out of the 227/233. So he easily could of sold the bigger cam but he said i'd like the 227/233 more and i'd get more power of it because of wider power band.
brothaslide
Jan 9, 2016 12:11 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
