RW Dyno numbers: 370ci LT4, AFR 210 Elims, Dry sump
Old Jul 3, 2008 | 12:22 PM
96lt4vette's Avatar
I've been working on gradually building up a new engine over the past year or so. First I wanted to thank you guys for the great information as well as some great deals on parts . Hopefully this info will be helpful to someone.
It's finally done and I just got the computer tuned a couple days ago. Here are the details:
Engine specs:
Shortblock
LT1 / 4 small block
bore: 4.03" (JE pistons)
Stroke 3.625" (Cola forged)
6.0" rods (Compstar)
Static compression 10.96:1
Comp Cams Hydraulic roller cam, specs at .05" lift:
Intake duration 230, .622 valve lift
Exhaust duration 236, .624 valve lift
Lobe separation: 112.0
Installed 108.0 intake center line
Caddy racing lifters
Oil system:
Johnson's 4 stage dry sump pump (3 sunction stages all in the pan)
Hamburgers 3 stage dry sump pan with extra scavenge fitting/tube added
custom oil tank
Canton oil thermostat and earls cooler
Intake:
Ported LT4
42lb injectors
58mm throttlebody
Heads:
AFR 210cc LT4 Eliminators, competition ported
Other:
Trans: ZF6
Clutch: Carolina stage 3
Exotic Muscle headers 1-3/4" primaries
Corsa 2-1/2" exhaust with Carsound 3" Cats
Delteq ignition
Meziere Electric water pump
180* Thermostat
The motor was built for a combination of street and road racing (HPDEs). Shortblock built and cam selection by Midwest engine tech in Mokena, IL. top-end, dry sump, etc was done by me.
My HP goals were ~500HP at the crank (~425 RWHP). Overall I'm very pleased with the result, particularly given the 'unknowns' of the AFR Eliminator heads and the practicality of fitting a dry sump system into a street C4 while retaining all accessories (AC, cruise, traction control, etc). That being said, getting it all in there was a massive pain in the butt. Among many other things I had to fab up new solid motor mounts which move the motor 1/4" back to clear the drive mandrel and also clear the oil fittings on the passenger side. No frame or structural mods were made, though.
Here are the results:
RWHP Dyno graph:
Engine during assembly showing location of dry sump pump and drive mandrel (you can also see the tank pre-installation in the lower left:
Oil tank installed in factory battery location (battery is in the rear storage compartment):
Engine from driver's side:
Engine from passenger side:
Dry sump tank breather can and oil pump (it's down there somewhere):
Head Flow numbers (no intake fixture):
Lift 0.1 0.2 0.3 0.4 0.5 0.55 0.6 0.65
AFR Intake 71.2 138.7 202.2 249.9 281.5 286.3 281.2 276.8
AFR Exhaust 62.6 113.9 167.4 197.5 212.2 215.9 217.8 220.3
Here's an ENGINE dyno graph that we did to break in the motor and do a mechanical check. It was run with an LT1 carb manifold as the shop didn't have an FI controller. Open headers, no accessories:
Old Jul 3, 2008 | 12:40 PM
neil350's Avatar
Very stout numbers, good luck with the car!
Old Jul 3, 2008 | 01:27 PM
MEAN LT1's Avatar
Very nice combinations of parts. look slike it worked out well.
Old Jul 3, 2008 | 02:49 PM
hsyr's Avatar
Car put out impressive numbers good job! I'm curious doesn't a vette 6 speed and rear eat up more than a T56 and a 10 bolt or no?
Old Jul 3, 2008 | 03:02 PM
neil350's Avatar
Think so, believe C4s run a Dana 44
Old Jul 3, 2008 | 04:14 PM
Kory 88 Iroc Lt-1's Avatar
Nice numbers
Kory
Old Jul 3, 2008 | 05:48 PM
SS MPSTR's Avatar
Nice build, with impressive results. Congrats.
Old Jul 3, 2008 | 06:13 PM
87Aerocoupe's Avatar
Where did you get the valve covers, I'd like to use a stud girdle like that.
Old Jul 3, 2008 | 06:30 PM
joeSS97's Avatar
Nice work. It paid off for you. Enjoy it.
Old Jul 3, 2008 | 08:12 PM
SS RRR's Avatar
Thumbs up
very outstandingly excellent.
Old Jul 3, 2008 | 08:30 PM
T/A KID's Avatar
Very nice results, what valvetrain are you using??? Looks like your using the 3100 comp lobes. Looks like those Eliminator AFR heads work pretty good.
Where the flow numbers come from??
Old Jul 3, 2008 | 10:06 PM
96lt4vette's Avatar
Thanks very much for the kind comments, guys!
to answer your questions:
I'm curious doesn't a vette 6 speed and rear eat up more than a T56 and a 10 bolt or no? It has a dana 44 with 3:73's. I'm running synthetic in both the diff and trans, but not sure how much that helps. I honestly have no clue if there's much of a difference in drivetrain loss between the two, though.
Where did you get the valve covers, I'd like to use a stud girdle like that. It's a Melrose racing setup which includes the valve covers and stud girdle. I actually got the setup used off the board for $250. The only problem is that since the AFR heads have slightly different stud position from stock heads, I had to bend the valve cover mounting studs slightly (minor, though). I like the setup, and they clear the alternator which was the big trick.
what valvetrain are you using? All of the hardware that came standard with the AFR heads (2.08 / 1.60 10mm valves) except we swapped the springs for Comp Cams 953's. Trickflow 7.1" pushrods, Crane gold 1.60 rockers, GM Caddilac Racing lifters.
I'd like to run it up a little past 7K to see how the valvetrain keeps up. Not going to make any more power, but good to know if I can hold it in gear longer if I need to!
Old Jul 4, 2008 | 12:11 PM
marshall93z's Avatar
Badass!
Old Jul 4, 2008 | 04:20 PM
1989TransAm's Avatar
Is this by chance a 55mm camshaft? I still can't get over the lift for the duration.
Old Jul 4, 2008 | 06:05 PM
Stl94LT1's Avatar
I'm running its little brother, 224/230 605/622(1.6) 112+2.
