runs like crap
Old Apr 14, 2010 | 02:31 PM
mcmadman129's Avatar
runs like crap
I have a 95 Z automatic that I rebuilt the engine a few months ago. I have put probably put 2000 miles on it. Yesterday the car started running like its missing and has lost some power. I do not have a cat. converter on this car. The plugs and wires look good and no check engine light and no codes. Anyone have any ideas I am frustrated. Also before this happened the tank was filled with Speedway premium and had probably had 40 miles on that tank of gas. Please somebody save me!!!!!!!! Thanks in advance, Butch
Old Apr 14, 2010 | 03:02 PM
Queens94z28's Avatar
Can you be a little more specific? When does this happen? is the engine hot or cold? How does it idle? Does it start easily? Does it miss at the top end or all the time?
I would look futher into the basics....double check that you do not have a burned spark plug wire and check your fuel pressure.
Old Apr 14, 2010 | 06:42 PM
The car starts and idles normal and the miss (thats what I am calling it) happens all the time. It feels and sounds like a car with a clogged converter. It is sluggish and you hear a miss. Wires look OK and the plugs I will pull to look at tonite. I am wondering what the symptoms are if the opti is going bad. I thought the opti was either good or bad no in between, am i right or wrong on this? Any input is appreciated. Feel free to call me at 7652109012. Thanks again
Old Apr 14, 2010 | 09:04 PM
Opti is a possibility. I would check fuel pressure first. They can act up without being completely dead.
Do you have any mods done to the car? Miles? Anything been changed recently?
Old Apr 14, 2010 | 09:05 PM
moparman's Avatar
I'd edit the phone number out.
Did you look at the wires, coil, while it is dark to see if there is any arcing?
Old Apr 15, 2010 | 01:02 AM
ltrunner94's Avatar
its bound to be an ignition problem. same thing happened on my 94 firebird. most likely a worn cap/rotor, which was my problem.
Old Apr 15, 2010 | 01:32 AM
94CamaroZ28/SSClone's Avatar
Sounds like the OPTi is going bad.
dirtybird81
10
Jan 6, 2015 09:31 PM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
