runs a few seconds after you turn the ignition off
I'm thinking about buying a 97 z28 auto
with a comp cam, bee hive springs and 36lb. injectors.(this is all the info I have)
What would cause it to run after its turned off?
It sounds like its out of time...Cam has wrong degree or opti in wrong?
thanks for any help
thanks for any help
on old carbed vehicles this is caused by a number of problems. to much timing and posibly a little carbon buildup will get the pistons hot enough to detonate any fuel in the cylinder, but you would have to have a worn out carb or be tuned way to rich to get the fuel in the cylinder after the engine stops turning.
on a modern fuel injection engine you could have a similar set of problems. if the timing was to far advanced and the tune was way to rich or you had a leaky fuel injector that could also cause this problem.
F'n1996Z28SS
08-23-2023 11:19 PM
10-31-2016 11:09 AM
Alex Barnes
01-24-2015 10:21 PM
07-04-2005 05:00 PM
