Running Rich - How to Fix
Old Feb 9, 2004 | 04:45 PM
MaddHatter's Avatar
I'm running rich, I can smell the unburned gas while idling it's so bad... Should I upgrade my TB to a 58mm? Any other ways to increase the amount of air in my a/f mixture? Should I just get a good tune?
Old Feb 9, 2004 | 04:49 PM
Mystic95Z's Avatar
Are you running that hotcam kit on a stock tune??? If so, you will run rich and will need your PCM reprogrammed. I suggest either Madwolf or PCMForless. Both can do a good mailorder hotcam tune for a reasonable cost.
-Tony
Old Feb 9, 2004 | 04:51 PM
MaddHatter's Avatar
Can PCM4L do a mail order tune on an OBDII?
Old Feb 9, 2004 | 04:56 PM
Mystic95Z's Avatar
Yes, but it's a bit more expensive than OBDI programming. Check out www.pcmforless.com for pricing and info.
-Tony
Old Feb 9, 2004 | 04:58 PM
MaddHatter's Avatar
thx
DirtyDaveW
Dec 1, 2016 05:37 PM
Iamherefornow
Jan 26, 2015 04:57 PM
squarehead
Nov 21, 2014 08:02 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
MislMan
Jul 19, 2002 11:41 AM
