running raggedy
Old Mar 24, 2004 | 09:18 AM
Krager11's Avatar
running raggedy
I have a little problem that I think I already know the answer to, but I'd like some feedback anyway.
I recently installed a set of shorty headers on my 96 Z28, and you have to take the plugs out to make clearance to get the headers in on the passenger side. The car has run raggedy since. It misses when under a load real bad, especially after it warms up. I checked the plugs and wires. The wires are all fine, but I have one plug that is loose. Finger loose. I know it needs to be fixed anyway, but is that what's causing the miss?
Old Mar 24, 2004 | 10:29 AM
camaroguy94's Avatar
if it does it worse when it is warm, it sounds like the opti. same thing was happening to me
Old Mar 24, 2004 | 10:46 AM
Red96Lt1's Avatar
If it wasn't doing it before headder install, check everything that you touched during headder install.
Iamherefornow
Jan 26, 2015 04:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
