running larger injectors than needed. any disadvantage?
Old Aug 15, 2007 | 11:20 AM
trans9_5am's Avatar
My new setup is N/A and i am shooting for a power range of 400-425 RWHP. I was advised to get something around a 36 lb/hr injector but i have come across some racetronix 42 lb/hr injectors for sale. as long as i have the PCM mapped accordingly, will this cause any problems. i am running stock fuel pressure through the stock fuel pressure rails with a walbro 255 L/hr pump at the moment.
Thanks,
Brandon
Old Aug 15, 2007 | 11:29 AM
89TramsAmGTA's Avatar
Your idle may not be as good. Contolling the needed pulse rate at idle rpms and the amount of fuel being delivered becomes more problematic.
Old Aug 15, 2007 | 11:49 AM
trans9_5am's Avatar
my cam is a 236/242 .608/.576 on a 111 lobe and the target idle is set at 1000 rpms. it seems to have trouble ideling with the 36/lbers i have now. they are accel injectors and i would really like to get rid of them though.
Brandon
Old Aug 15, 2007 | 03:39 PM
1racerdude's Avatar
36's will work if you are tuned for them. When ya send your computer off for the tune tell them and they can tune them.
Old Aug 15, 2007 | 04:07 PM
jsetzer's Avatar
I have seen lots of posts with the accells being junk. I had a pair and never thought they were an issue, but lots of people don't like them.
Old Aug 15, 2007 | 05:45 PM
sbs's Avatar
sbs
I have 37# Racetronix on a stock engine and I have no problems. 42# on a 400RWHP engine would be less of an oversize than 37# on a stock engine.
Lots of other people have run 37-42# on a stock engine in anticipation of upcoming H/C work without problems.
Old Aug 15, 2007 | 06:45 PM
mrmint69's Avatar
I never hear anything good about those Accel injectors
Old Aug 15, 2007 | 08:22 PM
trans9_5am's Avatar
yea i know...i didnt start hearing all the complaints about them until after i bought my set....oh well i can always try to sell them on ebay.
i think i might give racetronix a call and see what they have to say
Old Aug 15, 2007 | 08:25 PM
95z28_m6's Avatar
I have 42s racetronix on a heads cam motor and dont have any problems. As long as the tune is good you should be fine.
Old Oct 19, 2007 | 07:29 PM
Blownbird355's Avatar
accels
48#'s here no problems
Alex Barnes
Jan 24, 2015 10:21 PM
edman
Jan 22, 2015 02:45 PM
birdblack
Dec 30, 2014 06:59 PM
nophix
Nov 30, 2014 10:26 PM
