Running Hot in Traffic
Old Jan 31, 2006 | 02:31 PM
zpastor's Avatar
I have a 1997 Z28 with the 6 speed.
On the hi-way it runs right at 180 degrees, but in traffic I see as much as 220 on the gauge. Is this normal?
Old Jan 31, 2006 | 03:05 PM
SS MPSTR's Avatar
Re: Running Hot in Traffic
Not uncommon. The secondary fans are programmed to come on at ~227*
Old Jan 31, 2006 | 03:09 PM
JohnD's Avatar
Not only that but what you are seeing is only in the head where the gauge sensor is. I put in a dual sensor which sends the temp from the water pump to the gauge and it never goes over about 210-212.
Old Jan 31, 2006 | 04:57 PM
Normal.
Old Feb 1, 2006 | 07:17 PM
zpastor's Avatar
Thanks for the info. I feel better about it knowing others run at that temp. Will a 160 degree thermostat help by itself, or do you have to reprogram the fans too?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
calaban
May 18, 2020 06:43 PM
Collector Car
Dec 17, 2014 01:12 PM
CLEAR
Aug 30, 2002 07:49 PM
