running engine without water
Old Mar 16, 2008 | 04:29 PM
95Blackhawk's Avatar
I have to turn my car around and that means I have to start it up. Right now, it has the radiator out and water only in the block but not the heads.
If I ran it at idle for 2 minutes max, would I potentially damage my heads? I just don't want to put this back together so it can run only 2 minutes.
Thanks,
Ben
Old Mar 16, 2008 | 05:07 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
I think you would be fine.
Old Mar 16, 2008 | 05:31 PM
user 647483's Avatar
You'll be fine, running without water for a few min won't hurt ya.
It's actually rather common practice while troubleshooting Optis or testing a new build.
Old Mar 16, 2008 | 05:47 PM
joeSS97's Avatar
I would NOT run it more that 10-15 seconds without water flow.You will get hot spots.Not a good thing.The heads especially.
Old Mar 16, 2008 | 06:38 PM
GreasyB's Avatar
Only for a min. Probly would not hurt it. But be quick about it.
Old Mar 16, 2008 | 07:14 PM
LSWHO's Avatar
I've done it with no belt on the car (no flow), but not without coolant/water at all. Wouldn't think it'd do anything if under a minute or so.
Why don't you just push it? I've pushed a car up a driveway with 2 of us. 3 would be easy. 2 is WORK, but doable.
Old Mar 16, 2008 | 07:56 PM
TasTe GOOD's Avatar
Yea, what he said.
oldschool
Feb 9, 2016 09:21 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Jazsun
Dec 29, 2014 12:14 PM
