running engine without water
I have to turn my car around and that means I have to start it up. Right now, it has the radiator out and water only in the block but not the heads.
If I ran it at idle for 2 minutes max, would I potentially damage my heads? I just don't want to put this back together so it can run only 2 minutes.
Thanks,
Ben
Thanks,
Ben
I've done it with no belt on the car (no flow), but not without coolant/water at all. Wouldn't think it'd do anything if under a minute or so.
Why don't you just push it? I've pushed a car up a driveway with 2 of us. 3 would be easy. 2 is WORK, but doable.
oldschool
Feb 9, 2016 09:21 PM
