Coil arching to itself.
Old Jul 20, 2005 | 04:25 PM
FlyboyZ28's Avatar
I replaced my coil about a month ago becasue the old coil I had was arching a large spark to the block. The coil I replaced it with now archs to itself from the plastic part to the metal sqaure mount. So I was going to send that coil back to MSD for a warrenty. For the time being I put a used stock coil, that as far as i know was good still, in the car. Well that coil is doing the same thing as the MSD. Is there anything other than the coil itself that could cause this.
Dan
Old Jul 20, 2005 | 05:10 PM
Ricardo's Avatar
Re: Coil arching to itself.
Check the cable from the coil to the Optispark.
How old is your Optispark?
Your plugs could be gapped too wide.
Old Jul 20, 2005 | 05:27 PM
93transam1234's Avatar
spark will go the easiest route, if ur plugs are fouled/gapped wrong the spark will be able to arch at the coil easier than sparking the plug.
like said above
also it could be a burnt/bad wire
Old Jul 20, 2005 | 11:33 PM
FlyboyZ28's Avatar
The wires are brand new less than a month old and when checking them at night for an arch i don't see them. The opti has around 5000 miles on it too. I've never heard of the plugs being gapped too wide that will cause this, but it seems like something to check into.
thanks
Dan
Old Jul 21, 2005 | 08:35 AM
im thinking you burnt a plug on the headers (it is very very common and has gone on noticed by a lot for a long time) Also may u have a cracked plug.
If all else fails you can bring it to a shop and them hook it up to an osiloscoop ( thats not how u spell it lol) and that can track down misfires.
Old Jul 21, 2005 | 04:04 PM
FlyboyZ28's Avatar
Your right I've never heard of burning a plug on headers.
Old Aug 29, 2005 | 07:16 AM
SNEAKY NEIL's Avatar
I have the same problem. My car has been stumbling more so i checked out my plugs and coil in the dark and the coil is arching from the main unit to the square metal housing. I can also see some light comming from the plugs but I thought a little was normal, is that true? Anyone else have more thoughts on this?
Old Aug 29, 2005 | 10:52 PM
GMRL's Avatar
I noticed the exact same thing, my coil was arcing over to the frame. Replaced the coil wire. Problem went away. I did notice however that a little lite was coming from the plugs, I checked on several other cars and they all did the same thing. I still feel a a misfire once in a while. Along with a ticking sound coming from the driver side. Trying to track it down, either an exhaust leak, arcing wire, or RR noise.
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Z Power
Sep 19, 2015 11:19 PM
