running 15w40 mobile 1
Old Mar 7, 2004 | 04:04 PM
slverbullet's Avatar
running 15w50 mobile 1
i'm assuming since i'm using a higher viscosity oil that my oil pressure is going to be a little higher. it averages at about 75% to max pressure for the first 5-10min and then averages down to about 50% pressure after that. i'm using the higher viscosity because i live in florida and with these hot days here, i'd like to make sure my engine is lubed. i know some other people out there use it too. does the oil pressure numbers look similar? and also, is this putting too much stress on my oil pump running at these pressures? i could always bump down to 10w30. this is my first time using the 15w50 (mobile 1 of course) and just wanted some thoughts on this. thanks.
dave
Old Mar 7, 2004 | 04:31 PM
FastZinTennessee's Avatar
Try the 0w40, you might like it better. Those numbers seem about right.
Old Mar 7, 2004 | 05:23 PM
yeah, thanks for the info. and from all of the reading i have just done (from the mobil 1 website and from alot of posts on here[should have done before i posted, but oh well]) i might try the 0w40.
dave
93440supernat
Jan 12, 2015 06:35 PM
Joes96z
Dec 13, 2014 07:48 PM
ferraricameron
Jul 29, 2002 07:46 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
