runnin on 6 or 7 cylinders?
Old Feb 11, 2006 | 06:48 PM
DiabloGT's Avatar
ok my exhaust is making backfire pops randomly like alot of em lol, and my friend has that meter to check if electricity is coming from the spark plug wires and all are but when you hit the throttle 2 of them like shut off... do you think this is the optispark? i just bought a cap and rotor kit so idk if i shoulda done that
thanks
Old Feb 12, 2006 | 05:14 PM
DiabloGT's Avatar
Re: runnin on 6 or 7 cylinders?
ttt help!!!!!!!
Old Feb 13, 2006 | 07:58 AM
hulettsz28's Avatar
Uhm...When my optispark got wet after a heavy rain when my car was outside, it did the same popping stalling spitting ****. It dried out and it was gone. So...my only suggestion...was your car in the rain or did you just wash it?
Old Feb 13, 2006 | 10:09 AM
hulettsz28's Avatar
I have no clue about the ses blinking with a misfire, because mine is OBD1 AND it is on anyways because of an 02 sensor that is off. no clue
Old Feb 13, 2006 | 10:22 AM
DiabloGT's Avatar
my ses turns on randomly for about 5 min, and it wasnt wet at all, it just happened i guess after the car sitting there for about a year or a little more...
Old Feb 13, 2006 | 10:25 AM
Mindgame's Avatar
Get it scanned. You could have more codes than you think.
-Mindgame
Old Feb 13, 2006 | 12:42 PM
ttop1986's Avatar
bad gas?
Old Feb 13, 2006 | 03:11 PM
DiabloGT's Avatar
no i got new gas and the old is out, and when we scanned it no problems came up and i think it might of said bad o2 but it couldnt of made the hc that bad in the inspection, its only supposed to have 1 hc and my car had 27!
Old Feb 13, 2006 | 03:18 PM
ttop1986's Avatar
Try putting new spark plugs in. Its cheap enough.
Old Feb 13, 2006 | 03:28 PM
DiabloGT's Avatar
i just put in new ones 1k miles ago... they were ngk ones
Old Feb 13, 2006 | 05:20 PM
orbitalshock2k's Avatar
I had the exact same problem, I needed to replace the coil pack. Hope that helps
Old Feb 13, 2006 | 07:34 PM
DiabloGT's Avatar
is the coil pack different from the optispark?
G-BODYT56
Jan 14, 2022 11:14 PM
94Maroz28
Oct 27, 2015 04:38 PM
jayblev95
Sep 26, 2015 09:44 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
