ruben jr 94z28 lt1
Old Dec 4, 2010 | 06:21 AM
  #16
Re: I beg your pardon?
Originally Posted by speedygonzales
Sorry but we already covered that.
Seems you been ignoring my posts for some time now.
Not sure why you feel you have to contradict and criticize all my posts recently. I was simply pointing out that the OP had cited DTC 16, someone (YOU) had already pointed out what happens with DTC 16...... but we still had people telling him it was the ICM.
Old Dec 4, 2010 | 01:47 PM
  #17
ruben jr's Avatar
Re: ruben jr 94z28 lt1
@ speedygonzales..i do have a consistent dtc16 according to the instructor and students..when they put the new flashed pcm the code poped up after test drive, they reset it, test drove it, light come on again, they put the scanner and again dtc16 came back again.my car runns good for about the first 1-4 minutes,then stumbles for about 3-5 seconds as if it wants to turn off while driving, the service engline light turns on. and when it is driven about 20 miles,when i turn it off, it wont start for a while. it will crank but not start..just yesterday i drove it for about 10 mins..turned it off..turned it on and drove around the block and it stumbled all the way back to the house..so i drove it about 5-10 mph home
Old Dec 4, 2010 | 05:50 PM
  #18
Guest47904's Avatar
Guest
With reference to the DTC 16
Check all the connections between the opti and the PCM for signs of corrosion or anything else unhealthy.
If that all looks good, put a scope on the red/black wire and look at the square wave while the engine is running. See if the signal drops out occasionally.
Based on the symptom, the problem, and code. Neither a tune up, nor an ICM is warranted.
Stick to the problem and it's symptoms and do good investigation. This is the perfect time for your instructor to pull out the scope and review it with the class.
Don't simply buy an opti. YET.
Old Dec 4, 2010 | 06:34 PM
  #19
slopokrodrigez's Avatar
Hey get back in your seat
If you're not gona get along with the others, I'm gona have to call the principle. Now get back to your seat.
Old Dec 4, 2010 | 09:13 PM
  #20
Re: Hey get back in your seat
Keep it up.
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Moore94Z
Sep 2, 2002 07:52 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
Brad122470
Aug 2, 2002 08:55 AM
