Rubber and metal hoses
Does anyone know the part number or where can I order online the 2 hoses for my camaro LT1 1994 that are rubber and metal?
1 is form the water pump to the engine and the other one is from the radiator to the engine.
thanks
thanks
I dont know how injuneer is able to help all of you out the way he does but he is right again that website has everything on it that you really would need to know about an f-body camaro. Also though you could go to summit racing and find plenty of hoses there. You can by those individual hoses which those two run for around thirty or forty dollars a piece or you could buy the whole set also on summit racing. Its the good year hose set and it comes with six different hoses the complete kit for your car and runs about 110.00 which i think if your gonna replace some you should just replace all when it comes to hoses because with them it could be the smallest leak a sip and your overheated and on the side of the road.
