Rpm surging... why?
Old Sep 18, 2003 | 11:33 AM
Robert95z's Avatar
Rpm surging... why?
My car idles extremely low... like 600rpms it was drop back and forth from 700-500 when it gets to 500 the car tries to die. It hasnt died yet, but its trying. Not only this but my converter is going back... and on that note should I A. Get a aftermarket converter or B. get a stock converter (free) and drop some 3.23s in replace of my 2.73s
-Robert
Old Sep 18, 2003 | 11:36 AM
madwolf's Avatar
Might as well get an aftermarket converter if you're taking it appart. Also, if you're replacing the gears, go with some 3.42s or 3.73s, otherwise, find a used 3.23 or 3.42 rear. Will be cheaper doing it that way.
An A4 should idle at 550 in drive and 650 in neutral. When was your last tuneup and what has been replaced?
Old Sep 18, 2003 | 11:41 AM
Robert95z's Avatar
Im either going to buy a whole rear end with 3.23s from someone and he'll give me his stock converter. Or i'll be an aftermarket converter.
Last tune up? lol well i only have 45k miles but I did infact TRY to change my plugs and wires with my stock manifolds... Well it didnt go very well, basically the drivers side has new plugs and wires and the passenger side has stock plugs and wires
Old Sep 18, 2003 | 11:47 AM
madwolf's Avatar
I think you should complete that job first, then might want to replace your fuel filter (air filter too if applicable) and if the car feels about the same at higher rpms, it also may be the cat.
Old Sep 18, 2003 | 11:50 AM
Robert95z's Avatar
Alright well i'll go ahead and change my fuel filter today. possibly even my tranny filter...
But what do you think about my converter problem... Get an aftermarket converter and keep the 2.73s for awhile or get a 3.23 rear end and replace my converter with another stock... Im kinda leaning towards another stock converter, because If i do the converter now a gear install will cost so much more in the long run
Old Sep 18, 2003 | 11:54 AM
madwolf's Avatar
Why not buy that used rear AND get an aftermarket converter?
Old Sep 18, 2003 | 11:57 AM
Robert95z's Avatar
lol cause im a broke college kid
Old Sep 18, 2003 | 01:19 PM
quicksilver97ta's Avatar
One thing you might consider concerning the gears, I think your going to need a different "carrier" for ANY other gears if you have a 2.73 rear. However with the 3.23 rear you could install 3.73's or 4.10's at a later date. So keep that in mind when thinking about gears.
Old Sep 18, 2003 | 01:21 PM
madwolf's Avatar
That's true. Just go with the 3.23 rear and stock stall for now.
93 RedBird
Nov 15, 2015 08:24 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
Daluchman1974
Sep 11, 2015 06:12 AM
