RPM activated cut out?
Old Mar 29, 2004 | 11:20 AM
jtk's Avatar
jtk
I was thinking, it would be a good idea if some one had there electronic cut out switched on at higher rpms automaticly say 3,500 to 4,500 RPM. also connect at least a resonator to the cutout.
Old Mar 29, 2004 | 11:31 AM
ppmz28's Avatar
be a little more specific, what do you mean by this??
Dave88LX's Avatar
You could probably somehow rig up an MSD RPM activated window switch, may need to wire it up to a relay, not sure how much the cutout's pull or the switch can handle...
Old Mar 29, 2004 | 11:36 AM
derf'96SS's Avatar
I thought of something like that, it would give you your torque out of the hole and more hp the top end
Old Mar 29, 2004 | 11:43 AM
ppmz28's Avatar
oh I see, def. a good idea. why not manually close it at higher rpms or have someone in the car press the button for you???
importeater's Avatar
Even better.. Use a WOT switch
Old Mar 29, 2004 | 11:51 AM
ppmz28's Avatar
hey importeater, what does !cags mean in your sig.?? is that suppose to be !cats???/ thanks
Old Mar 29, 2004 | 11:55 AM
AxeGrinder30thZ's Avatar
He took off the CAGS cause he is a M6. That is a skip shift eliminator.
Old Mar 29, 2004 | 12:13 PM
Screamin93TA's Avatar
Hmm..I knocked off a .10 my last time at the track by keeping the cutout closed till a little past the 60' then I started opening it as I went down the track...DEFINATLEY makes a HUGE difference!
Old Mar 29, 2004 | 01:03 PM
Yep. Mines the 2.2k ohm resistor, the $.20 skip shift eliminator, not the rip off ones they sell.
Old Mar 29, 2004 | 01:34 PM
speedmiser's Avatar
But with a 6spd or a larger stall, you'd probably see more torque off the line with a cutout open. I could see how keeping it closed for a short while might help a stock stalled car at low rpm though.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
jackpawt883
May 21, 2015 12:34 AM
BLK1997Z28
May 7, 2015 03:01 PM
Redbird
Jul 25, 2002 03:50 AM
