Rough idle, hesitation etc
Old Apr 1, 2008 | 04:57 PM
  #31
socal96Z28's Avatar
Ok latest update! I am pressed for time so I only replaced the #7 spark plug wire with the Taylor OTVC kit, which worked and is an awesome kit btw. So no more misfirings on #7. Then I took it for a test drive, ran fine, had it parked for 10 minutes and then tried it again. No such luck it backfired, rough idle etc until eventually it would not crank at all. So I remember reading about others having heat soak problems with ICM. For sure! I let it sit for 4 hours till cooled down and it ran beautifully again. Today I replaced the ICM, did the spacer mod from shbox and it runs awesome!! One small problem remains, in stock programming the cooling fans do not come one at all, I checked the fuses and the relays and they are fine. I upload the hypertech program to the computer and the fans come on no problem. Any idea what Hypertech does different then stock? Thanks for all the help!!
KYWes
Jun 14, 2022 06:52 AM
Noct
Jul 14, 2015 01:18 AM
pete53
Jun 27, 2015 09:08 AM
Iamherefornow
Jan 26, 2015 04:57 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
