Rough Cold Idle
Old Nov 17, 2003 | 05:44 PM
Z28Boss's Avatar
Angry Rough Cold Idle
I just changed my EGR valve that was sticking open. Before my car would idle rough all the time, now it runs rough when it is cold but as soon as it gets to running temp, it is smooth. I havent checked for any codes since I changed the EGR and there might be some old codes in there still. Also, my car takes a LONG time to warm up. I can drive 15 min to work doing about 35 to 50 miles an hour and it still isnt all the way warmed up when I get there. Any input you guys would have would be great. What would cause rough idle only when cold.
Old Nov 17, 2003 | 07:00 PM
Z28Boss's Avatar
Forgot to ask, do I need to take a battery cable off for a while and reset the computer after the new egr. I didnt do that.
Old Nov 17, 2003 | 07:17 PM
ny_z28man's Avatar
Hey, im not 100% sure but I think if you disconnect the battery for a 1/2 an hour or so it resets your codes. Try cleaning your Idle Air Control valve. Buy some good carb cleaner and get all that carbon off the end of the valve and spray down in the hole to clean any carbon build up that may have collected there. Id give that a shot first. see-ya,
-Paul
Old Nov 17, 2003 | 07:39 PM
Z28Boss's Avatar
Sorry I forgot to mention that I already cleaned the IAC. I did that and cleaned the TB really good. Any other ideas, thanks for that suggestion though.
Old Nov 17, 2003 | 07:45 PM
ny_z28man's Avatar
check the secondary ignition system, fuel filter, & fuel pressure. If those are good and your sure your air filter is clean id look to see if any of your sensors are throwing codes.
Old Nov 17, 2003 | 07:50 PM
Z28Boss's Avatar
Fuel filter is changed, air filter was cleaned about 1000 ago, and i just had it scanned and the only code was the egr code 32. I changed the EGR after I got that code. This is getting pretty frustrating since I dont have ALOT of money to spend on this thing. Any other ideas??
Old Nov 17, 2003 | 07:58 PM
ny_z28man's Avatar
My car is currently displaying code 32 but it's running perfectly fine so I unpugged the vac line out of the EGR and I havent had any problems with it at all. try unplugging the vac out of the EGR and see if it still idles rough. your new EGR could be bad.
Old Nov 18, 2003 | 06:23 PM
Z28Boss's Avatar
Any other ideas??? Do most of you have the rough idle when the engine is cold and the idle is a little higher?? Let me know.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
markzzzz
May 8, 2015 09:21 AM
Noenav
Apr 30, 2015 01:06 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Gtpguy
Jan 26, 2015 04:50 PM
