rotten egg or sulpher smell?
Old May 25, 2003 | 06:45 PM
yorkie's Avatar
What is causing this, engine is 383.
Eric
Old May 25, 2003 | 06:53 PM
n2oCamaro's Avatar
Exhaust leak more than likely.
Old May 25, 2003 | 06:55 PM
mastrdrver's Avatar
Sounds like clogged cats. That is the only think that I heard that can make that smell. Though the guy at GM said that a bad EGR could make that smell, but I have had a lot of cars with a bad EGR and never made that smell.
Old May 25, 2003 | 06:59 PM
yorkie's Avatar
it pings on the 1-2 shift, after...
it goes into 2nd gear with a light load, it is a 383 too, I took the pipe off the egr and ran it and it still pinged.
Old May 25, 2003 | 07:09 PM
mastrdrver's Avatar
If it is pinging, your motor could be running lean and causing the cats to run hot which is not good and I think might be able to cause that that smell. Anyone else?
Old May 25, 2003 | 07:11 PM
yorkie's Avatar
I have accel's 30 pound injectors now????
stock 130,000 muffler and cat, come guys IDEAS????
Old May 25, 2003 | 11:53 PM
Lt1t56's Avatar
Dont know if this helps or not, but used to be a service manager for a Mitsubishi dealer, had the same complaint, usually after a lot of accelerating. Customer would complain of rotton egg smell from exhaust. Tech bulletin stated smell was due to low nickle content in catalytic converter, but converter still functioned properly otherwise. If customer continually complained about smell we could replace it with a converter with higher nickle content.
Old May 26, 2003 | 12:14 AM
DjArcadian's Avatar
Your EGR is leaking.
Old May 26, 2003 | 12:16 AM
yorkie's Avatar
explain please...
you seem to know that this is the problem.
Eric
Old May 26, 2003 | 12:42 AM
DjArcadian's Avatar
Someone else recently had the same problem and posted the solution here. Do a search.
Old May 26, 2003 | 02:19 AM
yorkie's Avatar
did a search but...
never found the thread, help...
93 RedBird
Nov 15, 2015 08:24 AM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
greenzee28
Sep 25, 2015 04:29 PM
damnyankee36
Sep 9, 2015 07:06 PM
