rookie here........bad misfire
Old Sep 3, 2007 | 02:18 PM
jollyman420's Avatar
lots of headaches on first performance build. havent even seen the road and engine has been in for a month.... i have removed o2 simply because have no exhaust yet but the read around 450 at start up. map volt 2.5 running 4.76 off. iac 132 start up and 68 warm. tps volt at .66 blm at 128 both side off and 138 left and 160 right running......all with snap on scan tool
car starts real ruff need to push gas to get it to start adjusted thorottel stop screw and makes iac go down and starts easier but idles way higher than what scanner says desired idle of 850 around 1000 but still sounds like a bad miss any help please this needs to see the road soon before snow falls
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
Schul365
Aug 22, 2015 10:00 AM
Girrrrl
Aug 20, 2015 09:26 AM
zajones
Jul 30, 2015 02:18 PM
