Roller tip question
Old Aug 12, 2007 | 08:28 PM
Romero155's Avatar
Roller tip question
So i know that the roller tip rockers are inferior to full roller rocker design, but how many hp/tq do you think i will see from a 1.6 Comp Cam NSA design?
Old Aug 12, 2007 | 09:10 PM
CustomSSI's Avatar
If your going to the hassle you might as well upgrade to full roller rockers. If you go to 1.6 you should highly consider new valve springs as well...
Old Aug 12, 2007 | 09:20 PM
Romero155's Avatar
Well i have already have the rollertip rockers, springs, guidplates, pushrods, and new studs. I got a good deal on all of them but i was considering selling the roller tip rockers. But how much hp/tq you think it will gain?
Old Aug 12, 2007 | 09:31 PM
wrd1972's Avatar
I have always thought that the roller tips free up more HP than the fulcrum bearings.
Old Aug 12, 2007 | 09:36 PM
Romero155's Avatar
Full Roller Rocker have the roller tip as well as the roller fulcrum bearing, i thought it would allow less friction compared the the roller tip standard casing
Old Aug 12, 2007 | 09:45 PM
Stl94LT1's Avatar
You may pick up 5-10 hp with the 1.6 roller tips, mainly from the increased lift.
Old Aug 12, 2007 | 09:46 PM
My thoughts are that the biggest benefit is in the trunion and that the roller tip gains would be minimal.
Old Aug 12, 2007 | 11:03 PM
JP95ZM6's Avatar
I agree. Here's how I look at it:
Work is force times distance. There isn't much distance of motion at the rocker tip, as compared to the fulcrum. Nearly zero, in fact. And, the force is higher at the fulcrum than the tip. So, at the fulcrum, more force x more distance = more work done to overcome friction. So, more power can be saved ('made') by reducing friction at the fulcrum.
Old Aug 12, 2007 | 11:36 PM
Romero155's Avatar
Yea that makes total sense, yea im guessing in the ballpark of 5-10 rwhp w/ rollertips
Old Aug 13, 2007 | 12:16 AM
Z28SORR's Avatar
More distance at the tip, not less????
Old Aug 13, 2007 | 01:20 AM
JP95ZM6's Avatar
Distance in terms of metal-to-metal sliding, not up/down travel. The sliding distance (friction causing element of motion) is only as long as the contact pattern on the valve tip, or maybe 1/16 inch. Whereas the friction distance at the fulcrum is the radius of the fulcrum bearing surface x the angle of rotation of the rocker.
Old Aug 13, 2007 | 08:00 AM
I would say 10 was generous.
Old Aug 13, 2007 | 08:06 PM
Romero155's Avatar
Im going to see if I could use my friends dyno jet so I could do a before/after and see how much of a difference rollertips are over stockers
Old Aug 13, 2007 | 08:24 PM
wrd1972's Avatar
Yup.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
alex5366
Feb 17, 2015 09:07 AM
Queens94z28
Dec 20, 2014 09:11 PM
Hurin
Dec 13, 2014 07:38 PM
