roller rockers and poly locks!!!
Old Sep 19, 2004 | 03:08 PM
1badasZ's Avatar
Angry roller rockers and poly locks!!!
what am i doing wrong? does anybody else have a problem with their rocker nuts backing off? these poly locks aint worth a crap. is there some other style roller rockers i can buy?
Old Sep 19, 2004 | 04:10 PM
Fux0redImages's Avatar
Re: roller rockers and poly locks!!!
had that problem, had to re-adjust the valves 2 times. you gotta tighten the poly locks down until you hear a "click".
Old Sep 19, 2004 | 05:05 PM
Mtrhds94Z's Avatar
Tighten both together the last little bit, that usually works..
Old Sep 19, 2004 | 05:14 PM
Z95m6's Avatar
what did you end up doing on the dowel pin of your camshaft?
Old Sep 19, 2004 | 06:18 PM
Never had any trouble with mine. If your rocker studs are crowned on the top, they won't hold as well.
Old Sep 19, 2004 | 09:14 PM
1badasZ's Avatar
i tried tapping it but was scared of messing up something. it didnt seem to be sticking out to far or anything unless you cant really tell. i just put a new opti on. i guess the other one must have been bad when i got it. it went right on all the way flush to the timing cover with no problem so im hoping and praying that its ok. now it i can just work out the kinks ill be ok.
and another thing is for some reason something inside my car is smoking. coming through the dash. donno what that could be. it wasnt doing that before the head n cam swap
Old Sep 19, 2004 | 11:35 PM
Spinner's Avatar
What he said. They will click.
Old Sep 20, 2004 | 12:21 AM
blwnlt4's Avatar
your heater core is leaking in the dash most likely
Old Sep 20, 2004 | 12:47 AM
1badasZ's Avatar
would water be on the floor? it went out before and antifreeze was leaking into the cab on the passenger side floor.
Old Sep 20, 2004 | 12:52 AM
MY91Y84's Avatar
you tightne the adjusting nut to your lash setting...then tighten down the poly lock..back off a smidge on the adjusting nut while holind the locking part in place..then tighten the adjusting nut the smidge...
that locks the poly lock down then the adjusting nut is turned another smidge to lock it in
Old Sep 20, 2004 | 01:00 AM
BlackLT1_TX's Avatar
I can say, without a reasonable doubt, that it is your heater core. Thats what mine did. Fogged up my windsheild, then the puddle on the passenger floor board. Either by-pass it or replace it, not too big of a deal.
-James
Old Sep 20, 2004 | 04:13 PM
1badasZ's Avatar
-James
i checked and there is no water on the floor board. its not cold down here yet so the windshield hasnt fogged up. i turned the heater on and it blows fine. i have no clue as to what it is. could having the water pump hooked to the ignition fuse under the hood have something to do with it?
oldschool
Feb 9, 2016 09:21 PM
2QUIK6
Jul 15, 2015 07:46 PM
mrwz28
Jul 8, 2015 09:11 PM
