roller rockers and poly locks!!!
what am i doing wrong? does anybody else have a problem with their rocker nuts backing off? these poly locks aint worth a crap. is there some other style roller rockers i can buy?
Re: roller rockers and poly locks!!!
Originally Posted by Z95m6
what did you end up doing on the dowel pin of your camshaft?
and another thing is for some reason something inside my car is smoking. coming through the dash. donno what that could be. it wasnt doing that before the head n cam swap
Originally Posted by Fux0redImages
had that problem, had to re-adjust the valves 2 times. you gotta tighten the poly locks down until you hear a "click".
Originally Posted by blwnlt4
your heater core is leaking in the dash most likely
you tightne the adjusting nut to your lash setting...then tighten down the poly lock..back off a smidge on the adjusting nut while holind the locking part in place..then tighten the adjusting nut the smidge...
that locks the poly lock down then the adjusting nut is turned another smidge to lock it in
Originally Posted by 1badasZ
would water be on the floor? it went out before and antifreeze was leaking into the cab on the passenger side floor.
I can say, without a reasonable doubt, that it is your heater core. Thats what mine did. Fogged up my windsheild, then the puddle on the passenger floor board. Either by-pass it or replace it, not too big of a deal.
-James
-James
-James
oldschool
Feb 9, 2016 09:21 PM
2QUIK6
Jul 15, 2015 07:46 PM
