Roller Rockers, is this the normal sound?
Old Jun 18, 2003 | 07:55 PM
KOSletten's Avatar
Question Roller Rockers, is this the normal sound?
I just finished up the cam, heads, headers, roller rockers EARLY Tuesday morning. This is what the CC Pro Magnum SA 1.6 rockers sound like RR Noises There is a little ticky ticky noise, but no clackity clack noises Is this normal or might they be a bit loose? I set them to 1/2 turn past zero lash using the no.1 TDC and no.6 TDC method.
The car does get up and boogity, boogity, boogity now! Oh jeesh I can't believe I said that Boogity... what is that?
Old Jun 18, 2003 | 08:07 PM
Blk94Z28LT1's Avatar
doesn't sound right to me. I think i would check the adjustment. I'm finishing up my hot cam kit install this weekend, i hope mine doesn't sound like that.
Old Jun 19, 2003 | 06:31 AM
grygst76's Avatar
Re: Roller Rockers, is this the normal sound?
Go back and adjust them while the motor is running, I found hydraulic lifters like being adjusted while the motor is running to keep the lifters "pumped".
Old Jun 19, 2003 | 08:11 AM
Are you sure none of them are hitting the valve covers? Did you make sure that you installed all the rockers with the machined area for the rocker nut facing up?
Old Jun 19, 2003 | 03:18 PM
KOSletten's Avatar
The microphone does pick up a lot of extra noise so it's kind of difficult to tell from the video exactly what is coming from the rocker arms.
For my peace of mind I suppose I should pull the covers and adjust the rockers with the engine running
I did double check and sometimes triple check to make sure I had the machined area for the rocker nut up.
Thanks,
Kevin
Old Jun 19, 2003 | 03:34 PM
vampyr95Z's Avatar
After hearing your rockers I think i need to have mine adjusted.Sounds just like that.Will there be an increase in power once properly adjusted?
Old Jun 19, 2003 | 04:04 PM
grygst76's Avatar
today I went out and bought the gold 1.6 rollers and threw them on and you should hear the ticking but very little and yes if the valves are adjusted properly you will feel a slight improvement just while the motor is running loosen the nut until it starts to clack (you might have to take the socket off to hear it totally) then slowly tighten until it stops clacking, then either 1/2 turn or 3/4 depending on preference. do one valve at a time obviously and it should be golden!!
Old Jun 19, 2003 | 04:27 PM
turbo_Z's Avatar
they should tick but clacking is bad. just start the car with the valve covers off. back one off till it clacks and then slowly tighten it till the clack goes away.. proceed with another 1/2 turn and lock her down! do this for the rest of them. they are hard to hear with all the other noise but just take your time and listen... its not too bad.
Old Jun 19, 2003 | 06:28 PM
PoorMan's Avatar
I hear about people doing it with the motor running. Seems like the easiest way to do it. Is thier a problem with oil leaking out on the headers? I guess this would sux if you had OVC wires though.
Jeff D.
Old Jun 19, 2003 | 07:02 PM
KOSletten's Avatar
OK, I've done one side and it is very hard to hear when the rocker starts to clack. Most of them I backed off about 1/2 turn, and at that point you could feel that most resistance between the nut and rocker was gone, this is the point where the rockers started to clack. So I basically ended up back to where I was to start with.
Jeff D.
I didn't have problem. The oil just kind of oozes out of the push rod and over the rocker arm. OVC wires are no problem either.
Old Jun 19, 2003 | 08:10 PM
turbo_Z's Avatar
well if you did it the way i said then where you started was right to begin with ive done it this way on a couple cars and it works fine. you could also start at TDC and do half of them then go another 360 and do the other half but that takes a while and the lifters tend to bleed down but it works and you can spend more time feeling the valve lash. you can find the procedure in any manual like chiltons.
Old Jun 19, 2003 | 08:17 PM
You should not have to worry about the lifters bleeding down when the engine is not running. Once you find zero lash, add the preload and go on to the next one.
Old Jun 19, 2003 | 11:02 PM
KOSletten's Avatar
2,4,6,8 sure were a PITA It's extremely tough to hear what's going on with No. 8s rockers.
But at least I'm experienced now
Old Jun 22, 2003 | 10:52 AM
KOSletten's Avatar
I went back and adjusted the even cylinder bank for a 3rd time . This time I did it with the engine off and went 1/2 turn past zero lash. Along with tightening up the Y-pipe to the headers a bit more and putting a nut on the long alternator bolt things are little quieter now.
I find that setting the rockers while the engine is not running to be easier and more accurate, for me anyway. My wife does think I'm better with my hands than I am at listening.
oldschool
Feb 9, 2016 09:21 PM
HarleyZ28
Oct 5, 2015 06:23 AM
dfarr67
Apr 10, 2015 07:44 PM
Roadie
Feb 16, 2015 10:34 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
