Roller Rockers
Old May 12, 2012 | 11:20 PM
PaNaRaMuH's Avatar
Roller Rockers
Hello all. Just got my 1995 Camaro z28 running after my fresh rebuild/cam swap. The car currently has SA Crane Gold 1.6RR. The problem with them is on the bottom of the roller, some of the rockers rub against the spring retainers.
My question is..Is there a particular reason for this? Something not done right?
Or should I just change rockers all together? If that's the case, what are some good SA rockers?
Thanks.
Old May 13, 2012 | 06:25 PM
PaNaRaMuH's Avatar
Re: Roller Rockers
Originally Posted by cardo0
Not all rockers are made the same.
I can only think of 2 options: 1- send them back; 2- get the grinder out.
But any rubbing in the moving vlv train parts is unacceptable.
Sorry to hear/read this news after all your hard work.
U have my sympathy,
cardo
I can't really send them back, can I? These are the rockers that came with the car when I had it that the owner before the previous owner had put on.
It's not really a big deal. They still work, and I don't really think I can get the grinder out and do anything to fix the problem. My father says he doesn't like them and thinks it's going to cause an issue later on. Me on the other hand, I don't think it will.
I was just wondering if their were better rockers out there. I'm in it for longevity.
Old May 13, 2012 | 07:15 PM
ACE1252's Avatar
Re: Roller Rockers
What kind of springs and retainers are installed on the heads?
Old May 13, 2012 | 08:05 PM
Kevin Blown 95 TA's Avatar
Re: Roller Rockers
I had that happen with the Crane 10308 spring kit and Crane SA 1.6 rockers. I was changing things by the time I noticed it, so I never resolved the problem.
Old May 14, 2012 | 04:57 AM
Guest47904's Avatar
Guest
Re: Roller Rockers
Some of them touch????????? Did you make sure you put them all in with the flat on the trunnion UP?
Old May 14, 2012 | 06:28 AM
DirtyDaveW's Avatar
Re: Roller Rockers
I had the same issue when I went to a 1.55" spring diameter. Really chewed them up by the time I noticed. You can switch to some CC Beehive springs to get some clearance or you can swap your rockers for some CC Ultra Promags and sell your current Crane rockers to defray some of the expense.
If you go to the Beehives, you 'can' change the springs while the engine is in the car/heads on. I've done it and so have others. You just have to put the piston at TDC or you can apply air pressure to the cylinder to keep the valves up.
Old May 18, 2012 | 01:59 PM
PaNaRaMuH's Avatar
Re: Roller Rockers
Thanks for all the information. Sorry I couldn't get on and respond sooner. Work, lol.
But yes, some of the rockers touch the retainer. The car has CM612 valve springs, titanium retainers and 10 degree locks. Valve geometry is good.
Looked at it a yesterday and found the problem. I know the problem is with the valves, as some of the tops sit lower then the others. I have no idea... It's not much lower, but you can tell the difference if you get eye level.
I may end up going NSA with guide plates. What are my options for NSA rockers?
I just need the car to last until the end of this summer. Then it's getting tore down, forged, stroked, and sprayed.
Old May 18, 2012 | 09:15 PM
DirtyDaveW's Avatar
Re: Roller Rockers
I went with CC Ultra pro mags.
7/16" stud
1.6 ratio
NSA
Old May 19, 2012 | 01:07 AM
mad95z's Avatar
Re: Roller Rockers
7/16" stud
1.6 ratio
NSA
And get rid of those 2.73's!
Old May 19, 2012 | 03:12 PM
us91bravo's Avatar
Re: Roller Rockers
I went with scorpion 1.6RR SA and i know a bunch of others that have also. But DirtyDaveW has a nasty camaro and if he says the cc ultra pro mags work then id go with them if your gonna build more power in the long run.
(by the way dave this is zach)
Old May 19, 2012 | 06:51 PM
DirtyDaveW's Avatar
Re: Roller Rockers
Hahaha.. Hey Zach! Sorry I didn't get a chance to visit with you after that last pass. The lightning and rain jumped on us pretty quick after I got off the return road.
Zach, If you got the scorpions to work for you (OP, request the narrow body scorpions if you go that route. The 'normal' width ones didn't work for me) then there's probably a cost benefit. Not sure but OP can check the prices.
Thanks for the recommendation Zach.
Old May 21, 2012 | 07:26 AM
us91bravo's Avatar
Re: Roller Rockers
Yea definetely go with the narrow body.thats what I have and they worked great. My buddy went with the normal ones and he has valve cover clearance issues
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
