Roller rockers.
Old Nov 16, 2003 | 06:25 AM
supercharged87's Avatar
Roller rockers.
Is it worth putting roller rockers on an otherwise stock motor? Also if so what size is stock? If stock is 1.5, is it worth going with a 1.6? Also does anyone use the Proform ones? Theyre on Ebay for $175, or should I just put out the $300 and get the Crane Golds? Thank you for any help in advance.
Old Nov 16, 2003 | 06:44 AM
formula383's Avatar
The stock size is 1.5. I would go ahead and get the 1.7's. You can get Scorpion 1.7's from http://www.flatlanderracing.com for $202.
You will also need new valvesprings, guideplates, hardened pushrods, and most will recommend using a 7/16 stud.
I am going to switch from my GMPP 1.6's this winter.
Old Nov 16, 2003 | 07:47 AM
That sux, you even have to change the valve spring. Do you have to with the 1.6s? Also will the roller rockers from an older 350 work on this car, because I have a set of old cranes off a carbed 350? Thanks for the help.
Old Nov 16, 2003 | 07:17 PM
formula383's Avatar
As far as having to change valve springs when changing to 1.6's I don't know for sure if you do, but if it were me I would anyway just to play it safe.
I don't know if the old rockers will work or not, but someone on here will let you know.
Old Nov 16, 2003 | 07:26 PM
Got-LT1's Avatar
You can run 1.6rr on stock springs, I do. 10,000 miles with no problems.
Old Nov 16, 2003 | 07:57 PM
Heatmaker's Avatar
Advanced Member
tee hee. I had the same questions...are the Proform rockers any good? what are the benifits of 1.6's? Better yet what are the HP gains?
Old Nov 16, 2003 | 08:16 PM
Cman's Avatar
You can run 1.7 rockers now with a stk. motor? I thought that piston/valve clearance was pretty tight already going with 1.6 ratio.
I remember seeing a post not too long ago, someone posted about installing 1.7 rockers and it got a lot of response. I didn't read most of it so I'm not sure if he did it on a stk. motor or one built up for more p/v clearance.
G-BODYT56
Jan 14, 2022 11:14 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
