leaking after ewp install
Old Jul 8, 2007 | 07:28 PM
95z28_m6's Avatar
I just finished my heads and cam install. I used a new ewp from summit. I was filling the cooling system when it started pouring water out of the weep hole that is on the bottom of the pump. My question is do I need to plug the weep hole with the ewp? Or did u just do something wrong. Thanks.
Old Jul 8, 2007 | 10:23 PM
SS RRR's Avatar
You did put a freeze plug in the back side of the w/p where the splined shaft once was, right?
Old Jul 9, 2007 | 05:40 AM
sssalah's Avatar
You're not supposed to plug the weep hole. It's an indication that the seal is worn out. You wouldn't want to ruin your ewp motor by continuing to use it like that.
Old Jul 9, 2007 | 08:07 AM
95ttoplt1's Avatar
The EWP don't use the weep hole, yes the hole needs to be plugged. If you postion the freeze plug properly in the hole it will solve the problem.
Magenta_Hearts
Mar 25, 2015 10:24 AM
Jlo
Feb 3, 2015 09:41 PM
CARiD
Jan 27, 2015 06:27 AM
Queens94z28
Dec 20, 2014 09:11 PM
