roller rocker question?
Old Oct 10, 2006 | 10:27 PM
ZX636RIDER03's Avatar
Question roller rocker question?
i installed some gm 1.6 roller rockers on my 97 camaro and ive attempted to tighten them twice now. once when i installed them and again when i was getting a minor knocking from underneith the valve covers, the second time i tightened them i followed my chiltons book and put cyclinder one at top dead center and then adjusted the following rockers that it said, zero lash then 3/4 turn and then torqued the supplied center backout nut to 19 foot lbs at first the engine runs smoothly then after getting up on it for a duration of 50 to 100 miles it starts knocking all over the place more like a tapping sound. if any one can offer some advice i would really appreciate it.
Old Oct 10, 2006 | 10:59 PM
razor02097's Avatar
Re: roller rocker question?
are you sure they are clearing the valve covers?
Old Oct 10, 2006 | 11:28 PM
well thats a possibility i will have to look into that, that would be a pain if i had to change those out cause i think that the altenator will get in the way of new style valve covers. some guys at a local shop said that the they would work with stock covers though, i dont know if they did any fabricating to them though, thanks
Old Oct 10, 2006 | 11:45 PM
HardcoreRM125's Avatar
You gotta bend the little tabs on the inside braces of the valve covers. Crimp them up. They come down and are L shaped. You need to bend the L up to make it straight. It gives you about 1/16" more clearance, all you need for most all rocker set ups.
oldschool
Feb 9, 2016 09:21 PM
Roadie
Feb 16, 2015 10:34 AM
dawg irocz
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:33 AM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
