Rod questions for 383
Old Sep 6, 2008 | 08:41 AM
kgkern01's Avatar
I will be gathering parts here and there for my somewhat mild 383 rebuild. So far I have Scat 9000 Cast crank, LE3 heads and my block is a 4-bolt main block. Plan on shifting around 6500 and will NEVER see boost or nitrous.
My question is this, looking at Scat I-beam rods there are 3/8" and 7/16" bolt size rods. I know the 7/16" bolts are stronger, but do they make clearancing the block more difficult being wider?
Also, this crank says is for 5.7" rods, does that mean that's the only rods I can use, or is it possible to use 6" rods with this crank?
Old Sep 6, 2008 | 05:31 PM
MachinistOne's Avatar
The crank for 5.7 rods will work fine with 6.0 rods, your machinist will deal with the imbalance when doing the rotating assy.
Old Sep 7, 2008 | 10:06 AM
kgkern01's Avatar
That's what I was thinking. What about the rod bolt sizes and clearance?
Old Sep 7, 2008 | 12:38 PM
You will need to have the block ground on to clear the rods, that's not avoidable - cam clearance generally is not a problem with the rods that I have used for 383's, you will need to check that and correct if necessary in your specific application. The 7/16" rods are worth the minor extra grinding for the added strength they give, the Pro-I beam rod is a much stronger design than the 3/8" rod
Old Sep 7, 2008 | 11:20 PM
blue 79 Z/28's Avatar
i have 6" rods make sure you get the pro comp i beams with the 7/16 bolts. plenty of clearance. h beams have alot less clearance, especially eagle stuff. scat is pretty good though.
oldschool
Feb 9, 2016 09:21 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
Hurin
Dec 13, 2014 07:38 PM
Queens94z28
Nov 20, 2014 06:03 PM
