Stock Timing
Old Sep 7, 2008 | 10:45 PM
SpeedZ28's Avatar
Stock Timing
Could someone tell me what the stock timing should be on a 97 Z28?
Thank you
Old Sep 7, 2008 | 10:56 PM
Stl94LT1's Avatar
That's not an easy question to answer. The timing is controlled by the PCM and can vary from rpm to engine load.
Old Sep 7, 2008 | 11:07 PM
SpeedZ28's Avatar
I noticed that...lol. but is there a guidline to follow like at idle? I thought i read somewhere on here that it should be between 28-30. I have an after market engine with what i believe to be the factory tuning, but at idle my timing is much lower then this, and i have crappy short times compared to cars similar to mine. thought it could maybe be related. I have recently installed n20, im running 100 shot with np, no knock. I have a laptop hooked up to my obd and can monitor my timing, just wondered is there like a stock setting at idle, or on these types of pcms is there no standard and the comp just decides?
Thanks.
Old Sep 7, 2008 | 11:12 PM
Stl94LT1's Avatar
No, there are closed TPS timing parameters. Let me check my Tunercat bin files.
Stock closed TPS spark advance in my 94 Y-body LT1 is 20* at 800 rpms. I have added 4* for a total of 24* at 800 rpms in my modified tune.
Old Sep 7, 2008 | 11:26 PM
SpeedZ28's Avatar
I'll check mine tomorrow but that sounds about where i'm at.
Thanks for lookin.
HectorM52
Jul 30, 2017 11:46 AM
Jlo
Feb 3, 2015 09:41 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
