which Rod and main bearings for stock lt1 short block.
Old Nov 7, 2006 | 09:35 PM
snakeatinZ's Avatar
What are the best bearings to go with for a Stock short block rebuild. Also what rings should I wrap around the stock piston for nitrous use?
Part # 's and where to buy from would be killer!!!!
Thanks,
Steve
Old Nov 7, 2006 | 11:51 PM
TransAm396's Avatar
Thanks,
Steve
clevite H bearins..and using stock pistons for nitrous is completely useless..the stock pistons are junk no way around it. while your in there why dont you just put in new pistons?
Old Nov 8, 2006 | 12:08 AM
rskrause's Avatar
Moderator
Take a look here: http://web.camaross.com/forums/showthread.php?t=482824
Rich
Old Nov 8, 2006 | 05:59 AM
snakeatinZ's Avatar
Well then who makes a good piston that is the stock size? Something to handle a 150 - 200 shot. Part numbers???
Steve
Old Nov 8, 2006 | 10:20 AM
quickSS's Avatar
The stock LT1 piston is very good and can take a 150hp nitrous hit.
If you do want to re-ring, then Mahle makes the stock replacement rings, (they make the OEM piston and the OEM rings). I cannot recite a part number but it's in the Mahle catalog.
Karl
Old Nov 8, 2006 | 11:06 AM
rskrause's Avatar
Moderator
Karl
Agree, nothing wrong with the stock pistons for anything other than boost, very high rpm (7,500+) or large nitrous shots.
Rich
11racing
Classic Engine Tech
Dec 26, 2014 05:40 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
