Rockers
Old Jul 15, 2009 | 08:02 AM
HRE's Avatar
HRE
Rockers
Can someone tell me what rockers will bolt on a stock LT 1 with stock covers and whats involed if anything to make them work. Looking to put 1.6 ratio on. Thanks.
Old Jul 15, 2009 | 11:08 AM
NJ-LE's Avatar
HRE:
The Crane "Gold" 1.6 self aligning roller rockers work under stock 1995 rocker covers with no modifications. Non-self aligning rocker need hardened pushrods and pushrod guide plates and some mods to the stock rocker covers. Do a search about the mods. I think it can be as little as "squeezing" some of reinforcing stringers or in some cases cutting them out.
Old Jul 15, 2009 | 12:12 PM
Wild1's Avatar
I use the Comp Cams Pro Magnums 1.6. They fit under the stock covers but I nibbled the cross webbing out.
Later, I got the LT4 composite valve covers which easily clear the rockers.
Old Jul 15, 2009 | 12:19 PM
JAKEJR's Avatar
A couple of weeks ago, I did a heads, cam and rocker arm swap on my son's 96 LT1 Vette. I converted to Scorpion 1.7/1.65 NSA rockers. guide plates and hardened pushrods and they fit without any modification whatsoever under the stock Corvette valve covers.
I don't know if 'F' body covers are the same internally as 'Y' body covers but I do know that his stock covers DO NOT look the same, internally, as those shown on Golen's website. Apparently all LT1 covers aren't the same.
Hope this helps.
Jake
West Point ROCKS!
Old Jul 15, 2009 | 09:48 PM
HRE's Avatar
HRE
Thanks guys , Crane golds are out since they no longer excist for the car guys. Looks like pro mags are it.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
