Rocker Studs (stock or ARP)
Old Jan 26, 2008 | 10:22 AM
maybe2fast's Avatar
okay, last winter I did a CC503, 1.6 ProMags and PP heads with 3 angled valves blah blah.
I reused the factory rocker studs and think I should have used ARP studs...any opinions?
parts numbers also please if the studs are necessary.
Old Jan 26, 2008 | 10:44 AM
Stl94LT1's Avatar
I used my stock 3/8 rockers studs with my heads/cam LT1 for five years without a problem, even with a 605/622 lift cam for a couple of years. But recently for peace of mind switched to ARP 7/16" studs.
You need to tell us which size rockers (3/8, 7/16), before we can give you part numbers.
Old Jan 26, 2008 | 11:36 PM
mdenz3's Avatar
Are you running guide plates?
3/8 part number is 134-7101
Old Jan 29, 2008 | 12:19 AM
Steve in Seattle's Avatar
sucks that you already have the ProMags.
the biggest gain in stablity isn't from going ARP over OEM (though ARP is the way to go... VERY nice studs)... it's going from 3/8" up to 7/16" studs.
the thicker studs require different ProMags though, so upgrading to ARP studs probably isn't worth the cost now. JMHO.
You could try to off load the used 3/8" Promags on ebay to offset the cost of new rockers and studs I guess... but it's more a search for durability, not hp. Depends what your goals are I guess.
Old Jan 29, 2008 | 11:31 AM
maybe2fast's Avatar
I have guideplates under the stock rocker studs...
I have the 3/8 stem, I guess I messed up on that choice. With the Guideplates under the stockers, does that mess with the duration?
thanks
Old Jan 29, 2008 | 11:44 AM
Stl94LT1's Avatar
Nope, no effect on duration or lift.
Old Jan 30, 2008 | 08:53 PM
maybe2fast's Avatar
alright I will leave them be
Old Jan 30, 2008 | 09:19 PM
GreasyB's Avatar
Mine are stock studs and work just fine. I wouldnt worry about it.
HectorM52
Jul 30, 2017 11:46 AM
canbaufo
May 25, 2015 12:01 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
alphaauto
Jan 23, 2015 07:42 AM
