Rocker came loose one me...
Old Nov 27, 2004 | 05:45 PM
)2overt SS's Avatar
Noticed a ticking noise when I was driving today.. but didn't think too much of it because my right side header bolts have been lossening up and leaking lately.
So I pick up two friends and start heading downtown.. when all of a sudden, I hear clack, clack, clack, clack. I imediately pulled over and shut her off. Called up a tow truck (wasn't to far from home luckily) And just barely could the truck lift my car. $62.06 to go 4km pfff...
So I get home... and take of the valve cover (passenger side of course, so I had to remove the alternator etc lol figures) And turns out my #1 intake rocker was finger loose
I have no idea how this happend.. all my other rockers were fine. I must have forgot to tighten the poly lock, or maybe not enough? I installed my 1.6 RR at the beginning of the summer and have had plenty of WOT's.
I checked the pushrod and it's not bent, so I got #1 to TDC firing and adjusted it again. Went for a spin and everything seems fine now.
Watch out for those locks guy
Old Nov 27, 2004 | 06:26 PM
Z95m6's Avatar
Re: Rocker came loose one me...
You probably did lock them. Its just hit or miss wether or not it takes. I've locked mine and drove it for miles and they were fine. The first time i hit 6k some came loose.
Old Nov 27, 2004 | 08:01 PM
Mtrhds94Z's Avatar
Small detail, but that's #2 cylinder[first one, right bank, under alternator]
If you had #1[first cyl drivers side] at TDC, 'firing' when you did the adjustment, you are OK adjusting #2 'intake' valve with it in that position..
Also if #2 was at TDC 'firing' [even if you thought it was #1?]you are OK adjusting either valve on it that position..
Old Nov 27, 2004 | 10:32 PM
ScreamingChicken's Avatar
hey man, he could have been talking about the right side passenger in the back of his car. don't be so mean.
Old Nov 27, 2004 | 11:32 PM
Mtrhds94Z's Avatar
I hardly see where the post is 'mean' all I did was bring to his attention it was #2 cyl not #1.. and that can affect the valve adjustment..
Old Nov 29, 2004 | 05:22 PM
slp223's Avatar
this happen with stock springs they will bind in some cases with 1.6 rockers.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
