rocker arm's rubbing the top of springs ,why?
Old Nov 13, 2005 | 12:08 PM
  #16
93LT1355's Avatar
Re: rocker arm's rubbing the top of springs ,why?
Originally Posted by Bodacious Critter
You should not have had clearance problems with the beehives. You and Fbody1 both need to check for correct pushrod length.
Actually the reason I ran into problems was because of the lock I used that had the +.050. This left less of the valve showing so the SA rockers would rub. I have stock length pushrods and when I switched to the NSA rocker everything worked out fine. I have had no problems what so ever.
Old Nov 15, 2005 | 04:26 PM
  #17
Fbody1's Avatar
Cool Re: rocker arm's rubbing the top of springs ,why?
I may have found my problem, I recently bought new valves standard lenth maybe i should have got .050 longer so i am stuck with these now can i use locks that are +.050 to get the stem to stick up a little higher out of the retainer?
Old Nov 15, 2005 | 04:58 PM
  #18
1racerdude's Avatar
If ya go +.050 ya will have less stem above the retainer. A -.050 would work if ya don't run into coil bind with your lift.
RUENUF
Mar 13, 2016 03:39 PM
1775.Z28
Jan 11, 2015 10:51 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
