rocker arms for LT1 w/trickflow heads and CC306 cam
Old Nov 2, 2004 | 02:29 PM
AStockerifficZ's Avatar
From: Born in Chicago IL, Grew up in Aurora IL, Stationed in Jacksonville FL.
Lightbulb rocker arms for LT1 w/trickflow heads and CC306 cam
I recently bought a set of the Trickflow LT1 heads, and I have a question about rocker arm use, can you use the HOTcam kit rockers which are self-aligning with pushrod guideplates? I wouldn't think so because I always thought that guideplates were designed to guide pushrods to a non-self aligning(hence NON). And if not, will the rockers that come with the HOTcam kit work with the TFS heads if I remove the guideplates, I know it's hard to tell without putting the rockers on, but I don't want to be installing the heads, and come to find out that I need a new set of rockers. I went to the gmpartsdirect site and looked up the hotcam rockers, which I have now, and it said the rockers are good up to .575 lift. I bought the CC306 cam and it has a .510(intake) and a .540(exhaust) with 1.5 ratio rockers. With the GM rockers which are 1.6, the lifts are .540(intake) and .576(exhaust). Would this really be pushing the limit with the rockers, or will I be fine if I remove the guideplates and use the GM rockers? Or would I be better off just getting a set of Crane Gold rockers and using the guideplates? Its the last thing Im worring about with my valve train. Got comp R lifters, CC chrommoly pushrods, new heads with everything, GM bowtie roller rockers.
Old Nov 2, 2004 | 04:41 PM
llafro's Avatar
Re: rocker arms for LT1 w/trickflow heads and CC306 cam
You should be able to use the rockers from the hotcam kit if you remove the guideplates. You can't run the self-aligning rockers with guideplates. Everything I have seen puts the guideplates and NSA rockers as the stronger setup. But, if you already have them, the hotcam kit ones are fine.
1775.Z28
Jan 11, 2015 10:51 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
Queens94z28
Nov 20, 2014 06:03 PM
