rocker arm studs and nuts
Old Feb 25, 2006 | 05:03 PM
luckyou03's Avatar
I just installed 1.6 rr and the locking nuts that came with them wont clear my valve covers. Can I used the stock nuts with ARP studs?
Old Feb 25, 2006 | 05:11 PM
Javier97Z28's Avatar
Moderator
Re: rocker arm studs and nuts
If you're using comp pro mag's under stock valve covers, they *do* fit..
I didn't see what you were using though.
The only thing you need to do with promag's is cut up the valve cover supports some.
Old Feb 25, 2006 | 05:23 PM
luckyou03's Avatar
I using PVS rocker arms and not with stock valve covers. I just need to know with stock nuts will work with arp studs.
the rocker arms clear but the nuts stick way to high.
Old Feb 25, 2006 | 10:01 PM
Loadre's Avatar
Just try a set of conventional poly locks.
Old Feb 25, 2006 | 11:21 PM
luckyou03's Avatar
can you get those at local auto parts stores or do I need to order them online?
Old Feb 25, 2006 | 11:42 PM
SS RRR's Avatar
Your studs aren't your problem, but rather the adjusting nuts are probably taller. I'm using a different brand of adjusting nuts and ran into the same problem. All I did was use a ball peen hammer to knock a divit where the nut was making contact and have no worries.
Old Feb 25, 2006 | 11:52 PM
luckyou03's Avatar
I got some really nice valve covers and I dont want to knock dents in them and I doubt I could. There cast aluminum.
I just need to different nuts.
Old Feb 26, 2006 | 08:26 AM
Loadre's Avatar
Order them from summit, etc.
Devinfoote87
Parts Wanted
Aug 6, 2015 05:05 PM
realistyc
Jul 28, 2015 07:32 PM
JCSWS6
Jul 19, 2015 06:47 PM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
94Form
Jul 17, 2015 10:56 PM
