Rocker Arm Studs
Old May 15, 2005 | 05:39 PM
joe-96z1le's Avatar
Rocker Arm Studs
I'm currently running a stock shortblock with CNC Heads. Existing RR's are Comp Cams with 3/8" ARP studs. I'm looking to rebuild the engine as a 383. At what point does an upgrade to 7/16" studs from 3/8" become necessary? Is this dictated more by RPM or by cam lift? BTW, the cam I'm looking at running has a .570 lift with 1.6 RRs. I'd rather not spend extra money unnecessarily. Thanks.
Old May 16, 2005 | 07:20 PM
arnie's Avatar
Re: Rocker Arm Studs
The reason for a larger stud is to resist bending due to the forces of stiffer springs and rate of lift. Do a search for a thread that included 'Mindgame' and myself, among others, that may help you in your quest for an answer. Don't recall if thread was here, or in 'advanced'.
Old May 16, 2005 | 08:05 PM
Mindgame's Avatar
IMO, 7/16 studs belong on anything with 120+ lbs of spring (seat) pressure. Unless you like giving up a bit of your lift to stud flex I'd go ahead and bite that bullet.
-Mindgame
Old May 16, 2005 | 10:10 PM
SStrokerAce's Avatar
Yep I'm with Mindgame.... good studs and pushrods are not flashy but they make parts work the CORRECT WAY.... Ya get's what's ya pay for.
Bret
Quickss96
Jan 29, 2016 05:56 PM
FryedClutch
Sep 1, 2015 08:24 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
realistyc
Jul 28, 2015 07:32 PM
94Form
Jul 17, 2015 10:56 PM
