rocker arm question
Old Dec 1, 2007 | 11:01 PM
Lil_Ryan's Avatar
rocker arm question
i am goin to a 1.6 rocker arm. i have been reading all your opinions on them but still not sure what would be best for my application
the lift on my cam will be .544/.554 with the 1.6 and i plan on goin with a bigger cam in the future. is it okay to use the self aligning or do i need the non self aligning. i was thinking of using the promags
Old Dec 1, 2007 | 11:09 PM
hotrod18_69's Avatar
I would go NSA, more stable at high RPM's.. Just make sure you have a good set of hardened pushrods and guideplates.
Old Dec 2, 2007 | 12:43 AM
Lil_Ryan's Avatar
i do have good components to go with it. thanks for checking
Old Dec 2, 2007 | 04:00 AM
Lil_Ryan's Avatar
any other suggestions
Old Dec 2, 2007 | 05:10 AM
Romero155's Avatar
IMHO i would switch to NSA rockers w/ hardened pushrods and guidplate, gm guidplates. It gives you more room to grow into and are more stable than the stock SA rockers.
Old Dec 2, 2007 | 06:25 AM
cehan's Avatar
You probably are already aware that you must use LT1 specific guideplates; regular SBC guideplates do not have the correct spacing.
Old Dec 2, 2007 | 08:56 AM
Correct, you need the GM guideplates or the Isky adjustable's.
Old Dec 2, 2007 | 12:35 PM
Stl94LT1's Avatar
On LE's recommendation I just installed Trickflow guideplates, and they aligned near perfect. I'm almost certain these are the standard 23* SBC guideplates.
Old Dec 2, 2007 | 02:55 PM
MeanGreen97Z's Avatar
I used the Trickflow plates myself. Installed them yesterday and they look great! Car runs like a top and the valves adjusted really easily.
1775.Z28
Jan 11, 2015 10:51 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
thenewkid
Nov 27, 2014 09:41 AM
newby
Jul 25, 2002 03:22 PM
