rocker arm question
Old Jul 16, 2006 | 12:11 PM
95LT1conv's Avatar
rocker arm question
can you simply install a 1.6rr on the stock valve train w/out doing any other mods to heads, lifters, etc... also is there any need to switch the stud size?
Old Jul 16, 2006 | 12:44 PM
OBE1 95Z28's Avatar
Re: rocker arm question
I lot of guys just install 1.6 RR's and have no issues. Others have had coil bind causing brakage of push rods. I recommend changing your valve springs to prevent coil bind. Depending on which RR's you buy will determine if your studs need to be changed; easy to do.
Old Jul 16, 2006 | 12:46 PM
95LT1conv's Avatar
what springs would you recommend? im pretty new to all of this and need as much help as i can get
Old Jul 16, 2006 | 05:11 PM
95LT1conv's Avatar
ttt
Old Jul 16, 2006 | 05:44 PM
OBE1 95Z28's Avatar
The LT4 springs work well and are low cost.
1775.Z28
Jan 11, 2015 10:51 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
thenewkid
Nov 27, 2014 09:41 AM
newby
Jul 25, 2002 03:22 PM
