Rocker Arm Issue! Picture
Old Feb 28, 2007 | 07:28 AM
94_camm's Avatar
Ok are the rocker arm suppose to look like this like all on even(thier not tightened down yet)
-Scorpion 1.6 NSA
-just put in new pushrods and guideplates in last nite..
Old Feb 28, 2007 | 07:30 AM
mdacton's Avatar
get a pic of it where the wheel is on the valve tip
what guideplates?
Old Feb 28, 2007 | 07:46 AM
94_camm's Avatar
GuidePlates-Comp Cams 4800-8...........5/16
idk if these pics will help but here!
Old Feb 28, 2007 | 07:52 AM
You need GM guideplates p/n 14011051 or adjustable guideplates. You will see this same advice posted in nearly every guideplate thread.
Old Feb 28, 2007 | 07:55 AM
Z-RATED94's Avatar
Most have found that the GMPP guideplates are the way to go. But I can't tell from the pictures if yours are ok or not. Are all the roller tips centered on the valve tips? Are the pushrods centered in the slots of the guideplates?
Old Feb 28, 2007 | 08:25 AM
94_camm's Avatar
So its my guide plates that are making the rocker arms all off center?Could the pushrods be the wrong size? looking at the wheel on the tips they look pretty center but some wheels are half on/half off the valve tip!
Old Feb 28, 2007 | 08:38 AM
danhr's Avatar
set the valve lash on them and see what they look like....
Old Feb 28, 2007 | 08:42 AM
94_camm's Avatar
think that would work?
Old Feb 28, 2007 | 09:12 AM
bhop42's Avatar
You will need the Isky adjustable guides. Even the Gmmp rockers aren't perfect for the lt1. Small block chevy valves are located slightly different than lt1 heads.
Old Feb 28, 2007 | 09:15 AM
1racerdude's Avatar
These are NOT correct. Ya need different guide plates and pushrods from what I can see in the picture.
Old Feb 28, 2007 | 09:18 AM
94_camm's Avatar
you think like longer pushrods?
Old Feb 28, 2007 | 09:29 AM
1racerdude's Avatar
10-4
Check for proper length and pattern and order some.
Old Feb 28, 2007 | 10:40 AM
The GM plates work fine for me. They are not the same spacing as SBC plates. The adjustable give you the ultimate in alignment customization.
1775.Z28
Jan 11, 2015 10:51 AM
87Aerocoupe
Jan 10, 2015 07:27 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
newby
Jul 25, 2002 03:22 PM
