Rocker arm issue
Old Jun 9, 2013 | 02:54 PM
acid5868's Avatar
Rocker arm issue
I just replaced the head gaskets on the car. It's. 97 Z28, Still using stock rocker arms.
I have adjusted with engine off, even tried the engine running method. I get to the point its running great and idles smooth, no ticking or funny sounds. Now the issue is after a couple of start ups, it starts to tick and progressively gets worse over a matter of a day. First time I found the rocker arm for cylinder 5 exhaust was just rattling around and not on the pushrod. Readjusted then again only to have the same thing happen.
It's almost like the nut is backing off the stud. Any suggestions as this is driving me crazy.
Old Jun 9, 2013 | 03:29 PM
96m6lt1's Avatar
Re: Rocker arm issue
I am willing to bet the nuts are backing off.. a new set of nuts would be helpfull or just upgrade to 1.6s and NEW springs yes I know I am being a bad influence but you will want them anyway
Sent from my LG-P999 using Tapatalk 2
Old Jun 9, 2013 | 03:31 PM
You should be able to visibly tell if the nut is backing off compared to the others. Is it the same one, every time? If adjustments have been positively been made correctly, other considerations are something wrong with that rocker or lifter.
Old Jun 9, 2013 | 03:33 PM
acid5868's Avatar
Its the same one each time. I swapped them and it followed. And 96m6lt1 I've already started looking at 1.6's with some ls7 lifters and new pushrods.
Old Jun 9, 2013 | 03:40 PM
acid5868's Avatar
Bad influence, thats funny. Speaking of which I'll pm or txt you in a few after work.
Sauced
Apr 12, 2015 10:18 AM
carl.froehlich
Mar 13, 2015 12:38 AM
1775.Z28
Jan 11, 2015 10:51 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
