Rocker arm adjustment
Old Jun 6, 2005 | 01:23 PM
Black6spdZ's Avatar
I have comp cam 1.6 self aligning rr. what do i have to do to adjust them because i think that they are too tight?
Old Jun 6, 2005 | 01:25 PM
BUBBA's Avatar
Re: Rocker arm adjustment
Why do you think they are "too tight"?
Old Jun 6, 2005 | 01:28 PM
30696bird's Avatar
http://shbox.com/1/4th_gen_tech2.html#adjust_valves Maybe this will help. If not, NOONE can explain it to you. That's about as simple as it gets.
Old Jun 6, 2005 | 01:35 PM
Black6spdZ's Avatar
because i dynoed the car a few weeks back and the power falls off hard and the car misses. The opti is relatively new, so i think its either that or valve float?
Old Jun 6, 2005 | 01:37 PM
Compstall's Avatar
Pick a cylinder. Turn the crank until the exhaust valve just starts to open - stop and adjust the intake valve. Turn the crank over some more until the intake valve peaks open then starts to fall closed - stop halfway there and adjust the exhaust valve.
Old Jun 6, 2005 | 02:20 PM
BUBBA's Avatar
Compstall: Close but no cigar.
Replace the "Exh" with the "Intake" and you got it I.e., EOIC.
Old Jun 6, 2005 | 03:24 PM
Compstall's Avatar
Woops, mah bad. My 10-month old daughter decided it was time to play at 3 AM today....
....fixed it.
browenb
Parts Wanted
Jul 20, 2015 07:34 AM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
94Form
Jul 17, 2015 10:56 PM
Noer
Parts Wanted
Jul 4, 2015 05:13 PM
