Roadrace cam?
Old Apr 15, 2006 | 08:45 AM
Loony's Avatar
Roadrace cam?
Are there any OTS roadrace cams? Or am I going to have to go custom grind? I'm looking to make over 400rwhp with heads and I don't want the huge lift cams. Thanks!
Old Apr 17, 2006 | 10:03 AM
SStrokerAce's Avatar
Re: Roadrace cam?
The lift doesn't determine the valve spring life BTW.... unless you have a rule for XXX amount of lift don't put a artificial limit on it.
Bret
Old Apr 17, 2006 | 11:56 AM
limige's Avatar
Re: Roadrace cam?
in that case buy a good set of heads and have a properly matched cam ground for what you want..
Old Apr 18, 2006 | 04:38 PM
Loony's Avatar
Re: Roadrace cam?
Bret
I didn't bring that up because of valve spring life, I was thinking valve seat mostly. I was planning on doing some high speed time trials so running high rpms for extended times made me think...
Old Apr 18, 2006 | 06:34 PM
Re: Roadrace cam?
Seats are all going to depend on if you have valve bounce and the valve job, you can have lots of lift and still not have bounce.
Bret
Old Apr 19, 2006 | 01:45 PM
Loony's Avatar
Re: Roadrace cam?
That settles it then...thanks for your help!
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Nov 20, 2014 06:03 PM
Ken S
Jul 25, 2002 11:23 PM
