rk sport questions
Old Mar 26, 2005 | 07:32 PM
unvc92camarors's Avatar
rk sport questions
ok, been searching...
i was gonna order (or actually did) these headers last year but they were so backordered that i cancelled
well, i have enough money again and basically i want to know what all i need for hooking these up
i had :
rk sport headers- 450 on site +around 30 shipping= 480
felpro gaskets- can't remember price, i need 8 though, plus 2 for the connection to the y (connecting to custom cat setup so i don't need the last 1)
wires- any suggestions?
ovc kit- can't remember, is this needed? i thought i read somewhere it was easier to run the wires in the stock locations on these headers
headers bolts- i guess you can't (or wouldn't want to) reuse the stock ones, and are arp good and how much are they?
i guess that's it
sorry, just trying to get the budget in order to get these things
Old Mar 26, 2005 | 07:44 PM
slverbullet's Avatar
Re: rk sport questions
okay, first question...why 8 felpro gaskets plus 2 for y-pipe. i understand the 2 for the y pipe for the header flanges. but why not 2 felpro gaskets? you do understand that one gasket covers one side of the engine? and they are usually sold in pairs. and go with felpro 1406's. found here:
http://store.summitracing.com/defaul...2D1406&FROM=MG
ovc wires, i like them. you can probably use stock. i would prefer ovc wires. good routing and keeps them away from the headers. i also use the heat sleeves for the spark plug boots as well. found here (completely optional) and also in different colors:
http://store.summitracing.com/defaul...=egnsearch.asp
and header bolts, go with breslins. hands down one of the best header bolts out there. found here:
http://store.summitracing.com/defaul...%2D076&FROM=MG
edit: i forget the length you need for the header bolts. maybe 1" bolts... someone else can confirm this for sure. just search summit for the different bolts.
hope this helps.
Old Mar 26, 2005 | 08:29 PM
Bersaglieri's Avatar
Everything is basically covered above. I however ran my MSD wires in the stock area and it worked good. I had to re-route one wire that kept getting burnt but this was with Hooker LT's, so RK's may be better. I know a fella who went with OVC with his AS&M/RK's and hated it, so he might have been the one to say it wasnt good for those designed headers. For some reason I somewhat remember that being said too. Good luck.
-Dustin-
Old Mar 26, 2005 | 08:45 PM
i went with the ovc wires and went with the side mounts. i like them a lot better than the wires that actually mount to the valve covers. dont know that there is really an advantage/disadvantage to side mount though other than two different mounting locations. i just like the fact that its keeps the wires visibly away from the headers. to each there own really.
Old Mar 26, 2005 | 09:31 PM
hope this helps.
yea, sorry, 2 gaskets for the felpros
i was thinking 8 cylinders, 8 gaskets for some reason
thanks for the correction
i think i'll go stock location with the wires because it might be better than ovc (i swear if i find that post that said the wires are better stock i'll post it) and for the money saved on it
what kind of wires did you guys use on these? i'm sure they're some longer msd ones or something, and i've heard that msd makes good wires (heard mixed opinions on taylors)
off topic- dustin, emailed or p/med you back, can't remember which one
Old Mar 26, 2005 | 09:48 PM
Internet gnomes must have stolen it, I dont have anything in either spot.
-Dustin-
Old Mar 26, 2005 | 10:26 PM
i used taylor wires. the 8mm cut to fit wires. they are around $50 and are good wires. and i dont see how stock location for the wires could be anybetter.... but whatever. no harm in going with stock location though either. a good place to pick up some wires or whatever for your f-body needs, check out these places:
www.thunderracing.com
www.tbyrnemotorsports.com
or check out some of the other board sponsors. they all carry great products.
Old Mar 27, 2005 | 07:46 AM
Antz97ZNJ's Avatar
not sure if this matters or not but those rk's are an offroad kit...only smog friendly 1 3/4 shorties is slp
Old Mar 27, 2005 | 08:30 AM
well,in my county, they just check for a cat, if that, and then put it on the sniffer (no ca smog ***** checking everything for a carb #)
in december actually, echeck is going away here so i can do whatever the heck i want really
only reason i'm still gonna get rk mids is because they're comparable to lt's and won't decrease my ground clearance or screw up the rest of my exhaust
thanks for the help guys
Old Mar 27, 2005 | 10:39 AM
DugRat's Avatar
I used Accell Extreme 9000 wires and ran them almost in the stock locations. One thing I would recommend id replacing your motor mounts while you are putting on your headers, I didn't and the collector on the passenger side hits the front suspention when I get on it. I have new mounts waiting to be put in, but I have to remove the headers to do it. (not a lot of fun)
Old Mar 27, 2005 | 10:42 AM
jkipp84's Avatar
You can get the Felpro 1406's at Autozone, Advance, Pep Boys, etc. Also, while you're at the store, check out Mr Gasket Ultraseal gaskets for the haeder to y-pipe connection. I've had the best luck with them (stay away from the dead soft aluminum ones - I blew both sides out inside of a month). I run RK's too, btw
Old Mar 27, 2005 | 11:11 AM
you know the part # on those mr. gasket gaskets?
o, and you know if the 1409 felpros are good? i think i searched a post that said they worked better than the 1406s on rksports/as&m
o, and is replacing the motor mounts a good idea on a 50k mile car?
Old Mar 27, 2005 | 11:19 AM
jkipp84's Avatar
Not sure on the Ultraseals, but I believe they're 2.5".
I got a set of 1409's once to check them out against the RK headers. Dunno who said 1409's matched up, but they were waaaaay off! 1406's are the way to go. They have a metal center so if you want to match them to the header shape, a little trimming with a dremel and about 15 minutes will do the job.
Motor mounts wouldn't hurt. It's up to you though, you have to check to see if they're shot or getting close.
Old Mar 27, 2005 | 11:21 AM
thanks again man
i'll have to start writing down all these parts and #s
i'll take a look at those motor mounts while i'm at it too
just trying to stay on the budget you know?
Old Mar 27, 2005 | 01:35 PM
J96Z's Avatar
I'm in the process of installing RK's once I get my heads back from the machine shop. Im doing the 94-95 style on my 96. I bought ovc wires because I don't see how the stock location can be better. Stock location actually kinda sucks when it comes time to change wires. I've done it twice and both times it was a pita.
